How can I set a DEFAULT FME Workspace Header?
  • Aug 8, 2017 3:19 PM UTC
  • 54 views
fmelizard
Forum|alt.badge.img+22
I understand that under the Tools menu there is an "Edit Header" option – but this is done per workspace. Is there any way to set a default Workspace Header so I can always have my favourite settings on each new workspace I author?
courtney_m
Forum|alt.badge.img+23
  • Aug 8, 2017 3:43 PM UTC
If you edit the header of a workspace, then save the workspace as a Template, any time you create a new workspace using that template, it will start with the header of your original workspace. This isn't exactly setting a default header, but it at least gives you a way to reuse an already edited header.
-Courtney
