How can i make a translation fail on missing input PostgreSQL table?
  • Sep 4, 2023 12:12 PM UTC
  • 75 views
roman00
Participant
When reading a PostgreSQL table with FME Workbench (2023.1) that has been droped (or renamed) before, the error in the logfile looks like:
"Error executing SQL command ('select * from "schema"."table" where false limit 0'): 'ERROR: Relation »schema.table« does not exist".
Despite of this error the logfile says that the "Translation was SUCCESSFUL". (The parameter "ignore failed reader" is already set to NO.) I need to know, if a table has been deleted (or renamed).
So, how can i make the translation fail on missing input PostgreSQL table instead?
nielsgerrits
Forum|alt.badge.img+67
I can think of different solutions with their own disadvantages.
You can force a workspace to fail using a Terminator.
  • Check with information_schema.tables if the table you want to read exists before you read it.
    • Requires a SQLExecutor and a tester for each FeatureReader.
  • Use the NoFeaturesTester from the FME Hub to check for output.
    • This only works when the required table always has records or you will get false positives.
roman00
Participant
  • Participant
  • Sep 5, 2023 12:49 PM UTC
Thanks for your answer. If it was just a single workbench, these solutions would be fine. My problem is that I have many workbenches with many PostgreSQL tables and I don't want to customize all of them.
I'm more looking for an option like "ignore failed featuretypes" (same as "ignore failed readers") that I can set to NO so that the workenches will fail if a featuretype is missing...
