How can I connect to different ORA databases.
  • Aug 8, 2017 7:54 PM UTC
  • 82 views
perry
I have a desktopversion 2016 and 2017 withe shared public database connections
I want to connect to 3 oracle databases in different schema's because there are three separate citties. (i.e. DBConn1, DBConn2, DBConn3) The tables are however identical so I made one procedure in a custom transformer.
In the custum transformer multiple SQL Excecuters will select the needed items from different tables.
I like to use a workspacerunner to start the custum transformer.
How can I validate the separate Dataset (DB Conn1 to 3) in order to run my custum transformer for the three citties?
I have published parameters (DBConn1, DBConn2, DBConn3) but I did not managed it to enclose these parameters in the SQLExcecuter parameter (DATABASE/DATASET).
Also I did not manage to sent the parameter value from the workspacerunner to the
custom transformer.
The procedure has to run automatically for all 3 citties so I can't use a manual input as Parameter with Choise.
Do you have any suggestions to solve this problem?
erik_jan
Forum|alt.badge.img+26
  • Aug 8, 2017 8:09 PM UTC
Create a text file with the 3 database connections.
Then use a text reader to read the file and per line in the text file execute the WorkspaceRunner passing the database connection to the WorkspaceRunner as a published parameter.
That way you only need to change the text file if you get a fourth city.
perry
  • Aug 9, 2017 2:17 PM UTC
Your solution is simple and efficient. Thanks for your quick reply..
