Group By and pick up maximum value rows
Hi guys,
I have data which look like this:
|ID|Number|
|1|1|
|1|3|
|2|1|
|3|1|
|3|2|
|3|3|
I need to group them by ID and pick up only rows with highest Number value. To get such data:
|ID|Number|
|1|3|
|2|1|
|3|3|
Any idea how to accomplish this?
Thanks
Best answer by ebygomm
Sort by number in descending order and then a duplicate filter on the ID would also work. ID with highest number value would be output via Unique port
  • August 8, 2017
Here's one possible solution:
  • Aggregator with Group By on ID, generate list "Numbers"
  • ListSorter descending on list Numbers{}
  • ListIndexer to retrieve item 0 (highest value) from list Numbers{}
Am sure there are others.
  • August 8, 2017
It seems to work fine after fast check. Thanks
Forum|alt.badge.img+38
  • August 8, 2017
  • August 8, 2017
Seems simpler, didn't know about this highest value in duplicated filter funcianality.
  • August 8, 2017
It's because the DuplicateFilter preserves the input order, which in this case has been established by the Sorter. Pretty elegant solution, I agree.
  • August 8, 2017
You could also use a sorter to sort in descending order followed by the sampler with a group by on the ID field and a sampling rate of 1 with a sampling type of First N Features
  • August 8, 2017
I agree that the combination of a Sorter and a DuplcateFilter (or a Sampler) is a very elegant way, but there should be several ways as @david_r mentioned. These four ways flashed into my mind so far.
  • Basic statistics: StatisticsCalculator (Group By: ID, Attributes to Analyze: Number, Maximum Attribute: Number)
  • SQL application: InlineQuerier
  • XQuery & JSON application: Sampler(or DuplicateFilter) + JSONTemplater + JSONFlattener
  • Tcl application: Aggregator + TclCaller
FYI.
mark2atsafe
Forum|alt.badge.img+44
  • August 8, 2017
FYI.
The StatisticsCalculator was what occurred to me first too. I like that way. But like you say there are so many methods.
