GeoMedia/Oracle Format Attributes
fmelizard
Forum|alt.badge.img+19
I am using FME 2012 SP4 to exposed a number of GeoMedia Format attributes on our text features coming from an Oracle DB i.e. geomedia_text_string, When I run the WB the attribute name changes to oracle_element{0}.geomedia_text_string which looks like a list to me. I have tried to use list manipulators to get to the text string but a list is not exposed.
Any thoughts on how to get to these format attributes so that I can export them?
Cheers
fmelizard
  • October 9, 2013
Have tried exposing the attributes in the reader or via the attribute exposer ?
fmelizard
  • October 9, 2013
Yes I have, but somewhere the exposed attribute name gets modified.
Original exposed Format attribute name = geomedia_text_string
becomes
when I look at it in the visualizer
fmelizard
  • October 9, 2013
Have you tried to make use if the fme_text_string instead ?
fmelizard
  • October 9, 2013
Yes, but  I do not see it in the attribute in the visualizer
fmelizard
  • October 9, 2013
Can you copy the oracle element list into a new attribute?
fmelizard
  • October 9, 2013
None of the List transformers see the list oracle_element so I can't copy that attribute.
fmelizard
  • October 9, 2013
You can try to copy the list element attribute name and paste it into the attribute copier or creator.
fmelizard
  • October 9, 2013
Solution:
1 add all the oracle_element_* attributes in an attribute creator
2 connect the attribute copier  to the attribute creator  to copying the attributes.
3 disable the attribute creator
fmelizard
  • October 10, 2013
With FME 2013 you can replace your solution with a single attribute creator ( it does stay red) but the new attribute is created with the oracle list values.
  • November 20, 2013
GeoCookie ,
I having the same issue.  How do you
How do you specife the value for oracle_element{0}.geomedia_text_string>
Any help is much appreciated.  Tim.
