geolocation in FME Workbench
  • Nov 28, 2013 6:37 AM UTC
  • 75 views
Is there a way to geolocate a layer that is in a non-earth coordinate system? I can get three points to define the geolocation. I presume that this should be sufficient?
Regards,
Chris Mugdan
  • Nov 28, 2013 9:38 AM UTC
could you please elaborate a little, I'm not sure I understand what you're trying to accomplish. Some more details would help.
David
  • Nov 28, 2013 11:09 PM UTC
Yes, I should do that: I have some files in AutoCAD dwg format of floorplans. I want to geolocate (georeference?) those floorplans to make a layer with real world coordinates. I can get real world coordinates for points on the floorplan using Google maps but I do not know how to perform the transformations. I am at the beginner stage with this but I hope that my needs are clearer now.
Chris
  • Nov 29, 2013 9:51 AM UTC
this blog post from Safe might be a good place to start.
David
