FMEUniversalReader Open Parameters
  • Sep 24, 2015 2:53 PM UTC
  • 44 views
Is there a way to specify the sheet name when you open an Excel spreadsheet using the FMEUniversalReader in Python code? I am assuming that there is a parameter that you can add to the open() method, but I have looked at the documentation for the open() method and the parameters are not described.
Thanks
  • Sep 24, 2015 3:17 PM UTC
Hi
By far the easiest way to do it is to make a call to FMEDialog().sourcePrompt() (http://docs.safe.com/fme/html/FME_Objects_Python_API/fmeobjects.FMEDialog-class.html#sourcePrompt) and print out the results after having specified the sheet name in the dialog box. You can then copy/paste the relevant portions of the result into your production code.
Example:
import fmeobjects
def FeatureProcessor(feature):
    print "-"*72
    print fmeobjects.FMEDialog().sourcePrompt('', '')
    print "-"*72
David
