fme workspace reading wrong parameter
  • Dec 14, 2018 3:09 PM UTC
  • 9 replies
  • 66 views
I have a template that I call and run with parameters but one of the parameters can be like this "something - else", but it only read "something", I need the whole word. any ideas?
Thanks
Best answer by david_r
If you're using the command line to pass the parameter value, that is an important detail. If you pass parameters that contains spaces or certain special characters, you should always put double quotes around them, e.g.
fme.exe --BoundaryType "Node - MUX"
  • Dec 14, 2018 3:16 PM UTC
Can you post a minimal working example here?
the issue is with boundary type. it only read Node and forget about the rest. I try using in the definition Type : Text multiline and same result, wrong.
  • Dec 14, 2018 3:30 PM UTC
That's a funny one. I did a quick test but was unable to reproduce the issue using FME 2018.1.
Please try the attached template:
parameter_test.fmwt
I've had some experiences where parameter definitions have been corrupted, meaning that they've started to behave unexpectedly. In those cases I've had luck deleting the parameter and recreating it.
parameter_test.fmwt
using fme 2017.0
  • Dec 14, 2018 3:35 PM UTC
using fme 2017.0
Just tried with FME 2017.1, no problems... Consider recreating the parameter.
I try recreating as suggested same issue. keep reading Node
when I run the template from inside fme it works ok reads Node - MUX, but when I send a request and run fme from command line it only read Node.
  • Dec 14, 2018 3:47 PM UTC
thank you so much, that was the problem, I wasn't using double quotes.
