FME Server Multiple Email Notification
  • September 18, 2015
  • 134 views
Is there a way to send multiple emails in the "Email to" box of the subscription? I tried the format that Outlook uses, that is, each email is separated by a semi-colon:
email1@email.com;email2@email.com;email3@email.com
However, no emails get sent.
Thanks
Best answer by fmelizard
Try comma ',' between the email addresses.
fmelizard
Forum|alt.badge.img+19
  • September 19, 2015
  • September 22, 2015
Hi
Itay is right, Outlook uses a non-standard delimiter (semi-colon), whereas the SMTP standard dictates a comma.
David
That worked, guys, thanks.
