FME Server IWA issue with explicit userPrincipalName
  • November 19, 2013
  • 11 views
mschgraffer
Participant
  Hello,
In our company exists a forest-wide UPN suffix
company.it
 and almost all user accounts have the explicit UPN set to
fistname.lastname@company.it
. This value is also set in the Active Directory
userPrincipalName
 attribute.
  Now we have configured the fme server (FME Server version is FME Server 2013 SP4 - Build 13547 - win64) to perform IWA (SSO), so users authenticate through Kerberos.
Since we are given the Kerberos principal, i.e. implicit UPN (sAMAccountName@company.it), which does not match anymore with the
userPrincipalName
 (explicit UPN), the IWA fails, as can be seen by the fmeserver.log.
Thanks in advance for your help.
fmeServer.log:
Tue-19-Nov-2013 09:00:47 AM   INFORM   RequestHandler-Thread   408041 : (Login Module)     Authenticating single sign-on token "YIIH/gYGKwYBBQUCoIIH8jCCB+6gMDAu...".
Tue-19-Nov-2013 09:00:47 AM   INFORM   RequestHandler-Thread   408057 : (Single Sign-On)   Negotiation complete; authentication granted for user "MSchgraffer@SIAG.IT".
Tue-19-Nov-2013 09:00:47 AM   INFORM   RequestHandler-Thread   408023 : (Active Directory) Performing search on server with filter "(&(&(objectCategory=person)(objectClass=user))(userPrincipalName=MSchgraffer@SIAG.IT))"...
Tue-19-Nov-2013 09:00:47 AM   INFORM   RequestHandler-Thread   408024 : (Active Directory) Search retrieved 0 entries.
Tue-19-Nov-2013 09:00:47 AM   WARN     RequestHandler-Thread   408059 : (Single Sign-On)   Failed authentication because user "MSchgraffer@SIAG.IT" could not be found in Active Directory.
Tue-19-Nov-2013 09:00:47 AM   WARN     RequestHandler-Thread   401934 : Failed login by user YIIH/gYGKwYBBQUCoIIH8jCCB+6gMDAu... due to insufficient credentials.
Best answer by davideagle
I think that's definitely an issue to directly escalate to Safe Software support I'm afraid. Link at the top of the page.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
davideagle
Forum|alt.badge.img+21
  • November 19, 2013
