I upgraded a workspace with a dynamic writer from FME 2022 to FME 2024. When inspecting the schema before writing there is fme_date and fme_datetime time fields. When writing to geodatabase it created dateonly fields from the fme_date fields when using FME 2024. When writing to SDE we get a ORA-210 / ORA-308 (invalid field type). What is the solution to this problem? I posted this before as addition to another forum topic. However someone from FME suggested to make a new topic.
