fme_basename of WKT files not loading correctly
  • Oct 14, 2019 2:56 PM UTC
  • 73 views
I am using the WKT reader for text files containing each one WKT polygon.
I want to write them to shapefiles, using their basename as fanout.
But all files are getting the same value for fme_basename.
Forum|alt.badge.img+54
  • Oct 14, 2019 3:34 PM UTC
I see the same behaviour, can you use a text reader followed by a geometryreplacer as a workaround?
chrisatsafe
Hi @jwisb,
Another option here is to use a Directory and File Pathnames Reader and point to the folder containing the WKT files. Then use a FeatureReader to read in the files using the path_windows attribute that is created by the Directory and Pathnames reader to set the dataset parameter in the FeatureReader:
You can then expose the fme_basename in the Attribute and Geometry Handling Section of the FeatureReader in the <Generic> Port > Attributes to Expose.
Not quite as fast as using the WKT reader but gives you options if you want to fanout based on the basename.
Hope that helps.
