First input in Append is being entered twice.
  • Aug 20, 2020 9:04 PM UTC
  • 60 views
The circled number is exactly 2x the number of records in that input - an sde point file. This happens no matter which file is "on top."
In the translation log, the Total Features Read is exactly the right number.
Total Features Written is too high by exactly the number of records in the first input. All other inputs are appended correctly.
Does anyone know why this is happening?
Thank you,
Randy McGregor
Capture
deanhowell
Forum|alt.badge.img+24
  • Aug 21, 2020 1:54 AM UTC
Hello @ramcgreg​ What is being read in and what are the parameters that you have set for the reader?
I have seen something similar when reading in a DWG file that has features in model space that are being read through the viewport.
  • Aug 21, 2020 10:36 AM UTC
SDE point layers are being read. I have used default parameters. I just have them all pointed to a reader to append them (A GIS "merge.") It works beautifully, except for the doubling of records of the first input.
I have entered all point layers into one writer. Maybe a writer for each layer?
Thank you,
Randy
  • Aug 21, 2020 1:59 PM UTC
Thank you,
Randy
DuplicateFilter to the rescue. Seems to work, but no idea why it's necessary.
