Fill a list with attributes from another list
  • Jul 22, 2016 8:43 AM UTC
  • 77 views
In an excel file, I have 6 checkboxes. In my process, all the value are put in a single list called Method_ID.
I have to manage each half in two different way. So I have to put 3 in a second list, and the other 3 in a third list. Because the following process needs a list for the input.
If I use a ListBuilder to make the second list, I can't make the third in another ListBuilder as you can see :
Do I have to use the ListBuilders in parallele? The problem is that I'll have to manage the amount of object later.
Thanks for your help.
  • Jul 22, 2016 10:52 AM UTC
Hi @slerendu, the following process requires all of those three lists (6 elements, first 3 elements and last 3 elements)? If the current single list (6 elements) will not be used, consider creating 2 lists from the original Excel row features, without creating 6 elements list.
  • Jul 22, 2016 11:02 AM UTC
Hi Takashi, yes I need the 6.
The problem is that I'm not allowed to change the original extraction.
So you think that make two lists from one list can be done?
  • Jul 22, 2016 11:08 AM UTC
OK. The ListSampler from the FME Hub may be a quick way.
  • List Attribute: EXP_DEV_METHOD_ID{}
  • Sampling Type: First N Elements
  • Sampling Amount: 3
With the above setting, the transformer creates two lists (sampled and not sampled) and also preserves the original list.
  • Jul 22, 2016 12:56 PM UTC
Perfect. Thanks a lot.
