File not opening in workbench, still runs in batch script
Forum|alt.badge.img+38
Attempting to edit a workbench file this morning but the file in question won't open.
Choosing file->open and selecting the file does nothing - no error, workbench remains blank, wording in title bar still displays Untitled - NONE, file name isn't in the list of recently open files.
The script itself works fine and runs daily via a .bat file
We have upgraded to the latest service pack since I last looked at this file but it only seems to be this file that is affected.
Is there anything I can try to get this file to open up in workbench?
  • October 10, 2013
I suggest sending your workspace file to Safe. They might be able to isolate the problem and to decide whether it is due to a bug somewhere.
David
  • October 10, 2013
I found an errant fmw.recover file that appears to have been created a couple of weeks ago when the script was running overnight. Deleting that solved my problem
  • March 8, 2018
Had the same issue. The FME workspace did not open. Deleting the fmw.recover resolved it for me. Thanks.
fmelizard
Forum|alt.badge.img+18
  • March 8, 2018
Definitely sounds like an opportunity for some enhanced error checking. We'll get on it. @egomm if you still have the .recover file in your trash, would you mind recovering it and sending both it and the workspace to support@safe.com? Failing that, I'm we'll do our best to synthesize a corrupt .recover file and see if we can reproduce the issue...
  • March 8, 2018
4 years and 3 jobs ago, I don't still have the file in my trash @daleatsafe :-D
fmelizard
  • March 19, 2018
Oh yikes. I guess I should look at the timestamps of posts a bit more carefully!
