Fetch from the Lookup Table
  • Nov 30, 2017 6:02 AM UTC
  • 102 views
parashari
Hi Experts. I have an excel table 'lookup'(attached) with 2 sheets accounting and count. I want to add a column number in the count table wherein the value of number would be from the value attribute from accounting table with respect to the count attribute.
I have tried using a combination of sorter, counter, lists and aggregator but didn't get the desired results. May be I had tried somewhat other way.
Thanks.
Best answer by ebygomm
You can use a FeatureMerger here, with the Count table going into the Requestor port and the accounting table going into the Supplier and choosing the relevant columns (count/accounting) to merge on
Forum|alt.badge.img+54
  • Nov 30, 2017 8:18 AM UTC
