FeatureReader: single merged feature type
  • Oct 17, 2019 1:21 PM UTC
  • 5 replies
  • 244 views
fikusas
Forum|alt.badge.img+5
Is it possible to merge all feature types with all attributes using FeatureReader? <General> port is not an option, 'cause it gives geometry only without attribute information.
itay
Forum|alt.badge.img+19
  • Oct 17, 2019 1:34 PM UTC
The generic port does provide the attributes but you need to expose them, luckily you can use the import function in the attributeexposer and get all the attributes.
  • Oct 17, 2019 1:35 PM UTC
The <Generic> output port will give you both the geometry and the attributes, but you'll have to expose the attributes manually. You can verify this by sending the <Generic> port to the Inspector and click on an object and see the attributes on the right.
fikusas
  • Oct 18, 2019 5:15 AM UTC
Yeah, I know that. But in order to expose attributes I need to know what they are. Any other reader automatically exposes all atributes without manually instructing what attributes to expose. This is kind of behaviour I want from FeatureReader.
itay
  • Oct 18, 2019 6:55 AM UTC
You can vote up this idea: https://knowledge.safe.com/content/idea/24774/add-import-function-to-featurereaders-attribute-to.html
Or add a new one.
fikusas
  • Oct 18, 2019 8:09 AM UTC
