Extra parameters in WMS Reader
  • May 23, 2018 11:04 AM UTC
  • 74 views
rbovard
Hi all,
I'm using the WMS Reader and I'd like to use an extra parameter in my query. As far as I can see, only the ones in the `map options` can be set (widht, height, format, srs, time, elevation).
Is there a way to add an extra parameter, like concatening my KVP to the query?
Thank you in advance.
Rémi
Best answer by david_r
Have you tried simply adding the parameters in the base URL?
For example:
Any additional parameters specified in the URL will automatically be kept during subsequent calls to the WMS server, e.g.
  • May 23, 2018 11:18 AM UTC
For example:
rbovard
  • May 23, 2018 12:06 PM UTC
For example:
Merci David !
It did the trick, you rock :)
Rémi
  • May 23, 2018 12:17 PM UTC
Merci David !
Rémi
Always happy to help, Rémi :-)
