Evaluate an expression in a C++ plugin
  • Mar 9, 2016 12:13 PM UTC
  • 71 views
ahuarte47
Forum|alt.badge.img+4
Hi all, I am developing a C++ plugin with a new IFMEDevFactory.
The "processClause" method of the factory gets an attribute (TEXT_OR_ATTR-type) as an encoded string:
@EvaluateExpression(FDIV,STRING,<at>Value<openparen>mypath<closeparen>,MyModule)
How do I evaluate this to resolve the real "mypath" value?
Thanks in advance!
  • Mar 9, 2016 2:49 PM UTC
Hi
I do not have first-hand experience with the C++ API, but in Python it could perhaps look something like this:
import fmeobjects
encoded_text = '@EvaluateExpression(FDIV,STRING,<at>Value<openparen>mypath<closeparen>,MyModule)'
decoded_text = fmeobjects.FMESession().decodeFromFMEParsableText(encoded_text)
mypath = my_feature.performFunction(decoded_text)
It seems that the method decodeFromFMEParsableText() is located in IFMEString in the C++ libraries, however.
Hope this gives you some ideas.
David
ahuarte47
  • Mar 9, 2016 4:02 PM UTC
Thanks a lot david!!!! It works for me.
My plugin is a mixed CLI/C++ DLL, the code ....
// Expand expressions of Keywords ?
for each (String^ key in gcnew List<String^>(static_cast<IDictionary<String^,String^>^>(_keywords)->Keys))
  String^ value = _keywords->default[key];
  if (value->Contains("@"))
    std::string tempString = msclr::interop::marshal_as<std::string>( value );
    IFMEString* v = _fmeSession->createString();
    IFMEString* r = _fmeSession->createString();
    *v = tempString.c_str();
    v->decodeFromFMEParsableText();
    FME_MsgNum rs = feature->performFunction(*v, *r);
    if (rs==FME_SUCCESS)
      _keywords->default[key] = gcnew String(r->data());
    _fmeSession->destroyString(v);
    _fmeSession->destroyString(r);
Alvaro
  • Mar 9, 2016 4:06 PM UTC
Alvaro
Glad to hear you found a solution! Thanks for posting the working code as well.
