Esri Geodatabase (File Geodb Open API) in Mac arm64
  • Nov 5, 2024 1:20 PM UTC
  • 209 views
matiassalinas
I’m trying to follow the FME Form course from a MAC and one of the very first exercises is using a Esri Geodatabase (File Geodb Open API) writer.
Unfortunately I’m getting this error on the platform. Is there any workaround for this?
Best answer by crystalatsafe
Hi @matiassalinas
Esri does not yet support that platform, but we have an internal ticket open for when it does (FMEENGINE-80358). I’m sorry for any inconvenience and I will make sure to keep you updated.
A potential workaround would be to run macOS Intel FME under Rosetta2.
Also, depending on your FME licensing, you could also set up FME on a Windows virtual machine to use the File Geodatabase Open API.
If you want to continue to work through the FME Form course on the FME academy you can request a windows VM here: Virtual Machine Request.
Crystal
crystalatsafe
Forum|alt.badge.img+32
  • Nov 7, 2024 9:45 PM UTC
Hi @matiassalinas
Crystal
matiassalinas
  • Nov 11, 2024 7:38 AM UTC
Thanks for the help @crystalatsafe I will try the Rosetta 2 approach and then the VM request.
crystalatsafe
Hi @matiassalinas
Happy to help! Please let me know if you have any questions.
crystalatsafe
Hi ​@matiassalinas
Thank you for your patience!
Support has now been added, please install 2026.1 at: safe.com/downloads/
