ESRI Geo DB reader where clause
boubcher
Forum|alt.badge.img+11
Helle
we are looking to extract features based on created date, we created a published parameter ( syn_date) and in the reader where clause we use this expression
( CREATED_DATE>date'2015-02-09 13:00:00') and it's working
now when we use the publish parameter to specify the date we used this expression
CREATED_DATE>date$(Sync_date) this is not working
we inspect the syn_date attribute the value show this ( 20180120000000)
and in the publish parameter its shows the right format
Any idea how to fix this
Thanks
GeoDB reader
inspect
Published param
Best answer by takashi
Hi @boubcher, as you have observed, the value of a user parameter with Date/Time type will be internally formatted with FME standard date/time format. i.e. "%Y%m%d%H%M%S".
A workaround is: create a private parameter with Scripted (Python or Tcl) type to convert the format to "%Y-%m-%d %H:%M:%S" and then refer the formatted date/time string from the WHERE clause parameter.
Scripted (Python) Parameter Example
from datetime import datetime
dt = datetime.strptime(FME_MacroValues['Sync_date'], '%Y%m%d%H%M%S')
return datetime.strftime(dt, '%Y-%m-%d %H:%M:%S')
Scripted (Tcl) Parameter Example
set dt [clock scan $::FME_MacroValues(Sync_date) -format "%Y%m%d%H%M%S"]
return [clock format $dt -format "%Y-%m-%d %H:%M:%S"]
  • July 22, 2018
boubcher
  • July 22, 2018
@takashi
Excellent Takashi , I did also another workaround by creating 3 user parameter, year, Month, and day
CREATED_DATE>=date'$(Sync_Year)-$(Sync_Month)-$(Sync_day) 00:00:00'
Thanks Agaian
