Escape @ in pythonCaller
  • Feb 22, 2024 12:19 PM UTC
  • 118 views
sunsilk11
Hi I am using FME Form 2021
I am passing a ArcGIS portal login (including domain) as a user parameter
e.g. username@sss.co.uk
When I try to get the value in pythonCaller
portalAdmin = str(FME_MacroValues['ArcGIS_Portal_UserName']).strip()
It is coming as
username<at>sss.co.uk
I am unable to use this to login to my portal in pythonCaller.
Any idea how to escape the @ sign ?
Best answer by david_r
Try this:
import fmeobjects
username = str(FME_MacroValues['ArcGIS_Portal_UserName'])
username_parsed = fmeobjects.FMESession().decodeFromFMEParsableText(username)
portalAdmin = username_parsed.strip()
Documentation: https://docs.safe.com/fme/html/fmepython/api/fmeobjects/_utilities/fmeobjects.FMESession.decodeFromFMEParsableText.html#fmeobjects.FMESession.decodeFromFMEParsableText
dustin
Forum|alt.badge.img+36
  • Feb 22, 2024 12:25 PM UTC
What type of user parameter, and how is it configured? I was able to recreate your issue using a Text parameter with the HTML editor syntax. However, with a Plain Text (Uniline) syntax the @ symbol comes through as expected.
  • Feb 22, 2024 2:16 PM UTC
Try this:
import fmeobjects
