Error when trying to export to Dynamic CSV
  • Mar 10, 2016 3:32 AM UTC
  • 45 views
afod
I am receiving the following error when i try and set up a Dynamic CSV output for my workspace.
MULTI_WRITER: Error fetching dynamic schema definitions from reader 'GEODATABASE_FILE_1'
My workspace uses a feature reader to read in a GDB, then a spatial relator. The Desired output is a pivoted table 'flagging' which constraints my data intersects with. I can get this initially but i want to do some further transformation and map schema dynamically based on a look up table that will be changing often.
  • Mar 10, 2016 11:44 AM UTC
Hi @afod, if you are using a look-up table to configure the destination schema, you don't need to use reader schema. Could you please explain the situation in more detail? Need more concrete information especially about the Dynamic Properties setting.
