engine
  • Nov 15, 2024 12:53 AM UTC
  • 8 replies
  • 137 views
sterla
With a permanent licence fme desktop hit much engines do we have available ?
Best answer by hkingsbury
FME Form can run a maximum of 8 instances of fme.exe - https://support.safe.com/hc/en-us/articles/25407717203725-Maximum-concurrent-FME-processes-error
That can be parallel processing, workspace runners, Form (Workbench), inspector
danilo_fme
Forum|alt.badge.img+58
  • Nov 15, 2024 9:25 AM UTC
Hi ​@sterla
Do you have a floating licenses from FME Form (Desktop)?
Please, open the FME Licensing Assistant to check this information.
Thanks in Advance,
Danilo
sterla
  • Nov 15, 2024 9:27 AM UTC
I have a fix licence
danilo_fme
  • Nov 15, 2024 9:37 AM UTC
Hi ​@sterla
You have a fixed license installed in your machine, so you have just one engine locally.
hkingsbury
Forum|alt.badge.img+73
  • Nov 17, 2024 6:57 PM UTC
sterla
  • Nov 17, 2024 7:01 PM UTC
Thank you for tou answer , but In the case of having a fixe licence how much engine do we have initially is it come with one engine or nothing ?
hkingsbury
  • Nov 17, 2024 7:05 PM UTC
Engines aren’t really a concept in Form. As the link I previously posted says, you can run 8 instances of fme.exe (which is effectively equivalent to an engine)
sterla
  • Nov 17, 2024 7:08 PM UTC
Yes but in the case of having a fme flow with an engine and I want to replace my engine of fme form by the one used in fme flow is it possible
hkingsbury
  • Nov 17, 2024 7:34 PM UTC
I don’t quite follow/understand what you’re wanting to achieve.
FME Form and Flow use different licenses, they are not interchangeable. If you require additional capacity in regards to engines or Form it is best to talk to your reseller.
The underlying ‘engine’ that runs process on both Form and Flow is the same (assuming both are the same version).
