Dynamic Writer Map Info Extended
  • May 25, 2018 2:22 PM UTC
  • 83 views
Hey I might be missing something here...
I cant get the dynamic schema to work on the Map Info Extended Writer.
When i try to load this in it says that its cant find the schema and features cant be written...
"Cannot find a matching schema named 'STATEWIDE_V_PROPERTY_MP_ADDRESS' in the known set of schemas: 'VMPROP.V_PROPERTY_MP_ADDRESS'. Known schema sources are: 'Schema from Schema Feature, SDE30_2, SDE30_1'. Please verify writer feature type configuration."
Shouldnt the matching schema be named to the fme_feature_type not the table name? or does something happen when using a parameter in the table name.
The dynamic schema appears to work if i change the value of the table name to "STATEWIDE_@Value(fme_feature_type)" which seems weird.
I also cant uncheck the fanout dataset option. It unchecks then i click ok, then i go back in and its checked again.
Cheers,
James
richardatsafe
Forum|alt.badge.img+11
Hi @jamesleversha,
It depends on what your trying to read as the schema. I suspect you are not getting your schema form schema feature attributes. If that's the case I would edit "schema sources" and remove "schema from schema feature" so you just include the readers schema (SDE30).
This is a great tutorial series on dynamic workspaces. In particular if your looking for working with schema features then the "Dynamic Workflows: Destination Schema is Derived from a Schema Feature" will be useful.
https://knowledge.safe.com/articles/1050/dynamic-workflow-tutorial-introduction.html
Richard
Hi @jamesleversha,
Richard
Thanks Richard,
I will check this out when im back at work on Monday. I have already tried unchecking that schema from feature option.
I dont think it will ever find a schema that is named 'STATEWIDE_V_PROPERTY_MP_ADDRESS' because that is the name I want the table to be called and I have manually assigned that. The schema I am looking for is VMPROP.V_PROPERTY_MP_ADDRESS, which should come from the schema definition name: fme_feature_type shouldn't it?
Essentially, I dont understand why its looking for my table name in the schemas and not looking for the fme_feature_type attribute in the schemas.
And why does it work for the MapInfo standard writer with STATEWIDE_@Value(fme_feature_type) as the table name with all the same options checked?
Cheers,
James
@RichardAtSafe,
So i have tested this, and just wondering on the the exact same reader....
This works
But this doesn't
Cannot find a matching schema named 'STATEWIDE_V_PROPERTY_MP_ADDRESS' in the known set of schemas: 'VMPROP.V_PROPERTY_MP_ADDRESS, VMADMIN.LGA_POLYGON'. Known schema sources are: 'SDE30_2, SDE30_1'. Please verify writer feature type configuration.
I have figured this workaround, and it works. or is this the way it should be done in the fetaure writers when joining a string to a parameter?
@Evaluate(STATEWIDE_)$(TABLE_NAME)
Cheers,
James
  • May 27, 2018 11:07 PM UTC
Hi @jamesleversha, a possible reason for the error is that the value of "fme_feature_type" has been changed at some point in the workflow. Check also this point.
