Dynamic schema and feature types
  • Sep 13, 2013 4:24 PM UTC
  • 53 views
Hi
I have a workspace with Dynamic Schemas which I ran on 5 datasets all which have the same schema.
However, when I tried to run the same workspace on a new set of data which have different schema, it would not work because the Feature Type was still set to one of the previous files.  I cannot work out how to change the Feature Type, or disable it so that it allows for all feature types - otherwise this is defeating the purpose of using Dynamic Schema!
Thanks
fmelizard
Forum|alt.badge.img+22
  • Sep 13, 2013 4:49 PM UTC
the feature types to read parameter perhaps?
  • Sep 13, 2013 4:56 PM UTC
Where is the Feature Types to Read parameter and what should I set it to?
Thanks
fmelizard
  • Sep 13, 2013 5:21 PM UTC
Usually in the reader and  that depends on ypur input data type.
  • Sep 14, 2013 7:46 AM UTC
Did you get the following warning after running for the different schema source dataset?
During translation, some features were read that did not match a reader feature type in the workspace. This can happen if the reader dataset is changed, or a reader feature type removed or renamed.
If so, you maybe forgot to select "Merge Feature Type" option of the reader. Check "Merge Feature Type" and specify * (wildcard) to "Merge Filter" in the Feature Type Properties dialog box of the reader.
Takashi
