Data Inspector won't show data when I have an attribute from @Value
  • Aug 25, 2016 7:37 PM UTC
  • 7 replies
  • 202 views
jakethepainter
Forum|alt.badge.img+7
I'm trying to create a series of attributes based on values of other attributes (I have some FieldName/FieldAttribute combos that I want to turn into attributes on the feature). When I create an attribute called @Value(FieldName), anything I output to the Data Inspector won't show. It just shows ? row(s) and doesn't load anything. Is this a bug or am I missing something?
Best answer by ciarab
@jakethepainteryes you are right its an Inspector bug in 2016.1, where attributes are not displayed properly in the inspector but the issue has been fixed in FME 2017.
The workaround is
1) Add a Logger and inspect the attributes in the log.
2) Run with Full Inspection and either double click on the feature count after the transformer, or right-click on the feature count and select Inspect features, to view the attributes in Data Inspector.
itay
Forum|alt.badge.img+19
  • Aug 25, 2016 7:41 PM UTC
Which version FME are you using? If I remember correctly it is actually a bug in older builds
ciarab
Forum|alt.badge.img+10
  • Aug 25, 2016 8:03 PM UTC
The workaround is
jakethepainter
Thanks. I am using 2016.1
Do you have any tips on how to expose the attributes that get created by this @Value(FieldName) in the workbench? For example, for one feature I might now have an attribute called Material where for another I have an attribute called Height. Say I want to use a FeatureMerger on the Material attribute later in the workbench... Or write out the data to a csv. I'm a little confused about how to make use of the value-driven attribute name.
ciarab
  • Aug 29, 2016 8:06 PM UTC
Hi @jakethepainter you should be able to just use the @value attribute in the feature merger to merge the data that matches. But you can use the attribute exposer to then expose your new attribute values if you wish to write the data out to csv. I have attached a quick sample which will show you what I mean
If you have a lot of attributes to expose you might want to use the import function in the attribute exposer that way FME can scan the attribute values for you and import otherwise you can just type the possible values. Hope that helps!
jakethepainter
Thanks, this is very helpful. The AttributeExposer is a great idea. That makes it explicit and a little easier to manage in my case.
ciarab
  • Aug 29, 2016 8:56 PM UTC
Yes it can be quite confusing trying to work with @value attributes when you can't see the name, the AttributeExposer will give you clarity alright. Glad you managed to progress this despite the initial bug
Forum|alt.badge.img+54
  • Aug 30, 2016 8:57 AM UTC
The workaround is
If you have access to an older version of FME you can also use an earlier version of the AttributeCreator which will also work.
