Custom Transformer Question
  • Mar 27, 2019 11:18 PM UTC
  • 85 views
Hi There, I am working on a functionality that converts events table into feature classes. I have large number of tables that need to processed. In order to keep the process clean, I created custom transformer that I could call for all these layers, details below:
Issue: Once I call the custom transformer, for List Attribute option, it doesn’t let me put a value. I wanted to know the best way to resolve this issue.
Appreciate any feedback
Thanks
Jay
xiaomengatsafe
Forum|alt.badge.img+11
Hi Jay (@jayd3vl), Thanks for your question. I did some testing, and realized you might have uncovered a bug. But, I have an idea to help work around the issue.
I suspect, when you created the custom transformer, you didn't explicitly set the List Attribute in the ListExploder transformer as a User Parameter. Because in my testing, this parameter gets linked to a User Parameter, by default. I think this is not necessary, and likely a bug. I will look into it with the team.
However, in your scenario, I don't see a reason for exposing this List Attribute parameter in the main workflow. The list attribute is created by the FeatureMerger inside the custom transformer, with a static name "MergedList", and this is the list you will always want to explode in the ListExploder. Am I correctly understanding your scenario?
If my understanding is correct above, you can resolve this issue, by manually setting the List Attribute Parameter in the ListExploder to the list attribute "MergedList{}", this will unlink and remove the user parameter and remove the List Attribute as a parameter for your custom transformer "PointGenerator".
Hope that makes sense. Let me know, if you have any more questions.
  • Apr 8, 2019 11:30 PM UTC
Thanks for your comment, the step you described allowed me to get it working.
