Custom transformer propagating more attributes than desired
I have defined a custom transformer, and it is outputting more attributes than what I want. I just want to output these two attributes (network_id and lower_network_id):
But when using it in the main workbench, it is also outputting attributes from the original input features:
I assume this is is because they automatically propagate all source attributes forward, but I want to avoid this, I just want the two-column list. How can I achieve this?
Best answer by takashi
Try inserting the AttributeKeeper before the output port to keep only required attribute.
  • December 9, 2018
  • December 9, 2018
This works, thanks.
