Custom Transformer Parallel processing - runs only single instance and blocking
  • May 9, 2022 11:01 PM UTC
  • 49 views
stevenjh
Forum|alt.badge.img+5
I have a workbench to process some raster imagery, each image is stand alone in the processing done, so a clear candidate for parallel processing.
The workbench now looks like
imageI've set the group by to the image name (all unique), and run in both modes with the following outcomes:
'Process when group changes (Advanced)' - Task Manager shows only only a single FME instance processing, act as blocking, processing all files before it begins writing results.
'Process at End (Blocking)' - Task Manager shows multiple FME instances launched, but only one is doing any work, acts as blocking, processing all files before it begins writing results.
Both paths are giving correct results, I have removed any 'group by' within the custom transformer, I'm trying to understand what is going wrong in running in parallel.
Thanks!
itsmatt
Forum|alt.badge.img+48
  • May 11, 2022 7:22 AM UTC
What parallel mode is it set to? and what FME version are you using? how many processes do you expect to run based on the parallel process mode and number of cores?
