CSV file Fanout
  • Jul 8, 2013 5:43 AM UTC
  • 7 replies
  • 240 views
I am doing a fanout in writer for a csv file based on an attribute, say CSV_NAME. What I am getting is new folders with the name as CSV_NAME under which one .csv file is present with name as CSV_NAME.
What I need is that all my .csv files should be present under a single directory. Is that doable? Any pointers?
Best answer by erik_jan
CSV like Shape is a folder based dataset, which means a featuretype in this dataset is a file. So to generate files based on a attribute, you will need the featuretype fanout (a setting on the featuretype) as opposed to the dataset fanout that will generate folders.
  • Jul 8, 2013 6:26 AM UTC
What is the value of CSV_NAME when it reaches the Writer?
Try sending the features to a Logger and have a look.
David
  • Jul 8, 2013 6:32 AM UTC
The value is as expected say District1. Now, it creates a folder District1 with a csv file under it with name District1.
  • Jul 8, 2013 7:38 AM UTC
I guess you specified both of the "Fanout Dataset" parameter and the "Fanout By Attribute" parameter of the CSV writer. If so, cancel the "Fanout Dataset" parameter setting.
Takashi
  • Jul 8, 2013 9:54 AM UTC
Thanks Takashi. That suggestion resolved the problem.
adamajm
Participant
  • Participant
  • Dec 9, 2015 4:03 PM UTC
Hi, I am having the same issue, but only for CSV. Below are screenshots of the settings. I don't see two different options as mentioned in the reply from 2 yrs ago about Fanout by Attribute vs. Fanout by Dataset. I only see Fanout by Dataset stting, then within that, option select what "attribute to fanout on." In my case, i'm trying to use the timestamp (probably a common use case) to publish stored copies of the written data.
erik_jan
Forum|alt.badge.img+26
  • Dec 9, 2015 4:11 PM UTC
roland.martin
Forum|alt.badge.img+11
Hi Adam,
You're looking at the Dataset Fanout settings. For Feature Type Fanout, you need to look in the Feature Type Properties, and just set the file/layer name to an attribute value - something like the image below.
There's also more info here...
