create object based on list
  • Apr 25, 2019 2:10 PM UTC
  • 76 views
alc33
Forum|alt.badge.img+14
Hello!
I have points and on each point is attached a list of value, separated with ";"
point 1 : 1;4;5;6
point 2 : 6;5;8;3;10;45
I would like to duplicate each point as many time as there are values and pick only one of the value.
point 1 => 4 duplications = 4 points
duplication 1 : value 1
duplication 2 : value 4
duplication 3 : value 5
duplication 4 : value 6
.point 2 => 6 duplications
I would like to do this because it doesn't exist the fonction "contains" on attributefilter so I need the exact value on the field to separate my data. Because otherwise I will have used Cloner and then tester, but there is no way to import a list on"right values" like on attributefilter and I have a lot of value to write.
Sorry, maybe it's not very clear :)
Thanks for your answer
Forum|alt.badge.img+54
  • Apr 25, 2019 2:11 PM UTC
Attributesplitter to split on ; followed by a list exploder
alc33
  • Apr 25, 2019 2:57 PM UTC
Perfect! Thanks!
