Create line between points and closest location on line
  • December 20, 2022
  • 86 views
sunsilk11
Hi, I have a large point dataset and line dataset in ArcGIS. For each point A, I need to 1) create point B on the line which is nearest to the point A. Ensure point is snapped to line
2) Generate a line between points A and B
I have tried using NeighborFinder, with the line set as the base. However this doesn't create an additional point dataset on the line.
Any suggestions
nielsgerrits
Forum|alt.badge.img+54
You can use attributes _closest_candidate_x and _closest_candidate_y from the MatchedBase features from the NeighborFinder to add a point using the VertexCreator.
nielsgerrits
Added a sample demonstrating this.
PointToLine(2021)
