Couldn't connect to server with HTTPCaller
  • Sep 14, 2017 2:18 PM UTC
  • 462 views
stefanh
Forum|alt.badge.img+8
I am having trouble to connect to serveral webservices.
- ArcGIS Server REST API
- ArcGIS Online REST Service
- Geoserver WFS (with login)
The error I get each time is:
HTTP/FTP transfer error: 'Couldn't connect to server'
The connections are working in a browser (Firefox, Chrome). But none is working in FME.
I have tried several settings, but I can not get it to work.
Do you have any suggestions I can try?
I do not know where to search anymore.
Thanks,
Complete error:
HTTPCaller_2(HTTPFactory): HTTP/FTP transfer error: 'Couldn't connect to server'
HTTPCaller_2(HTTPFactory): Please ensure that your network connection is properly set up
HTTPCaller_2(HTTPFactory): No proxy settings have been entered. If you require a proxy to access external URLs, please ensure the appropriate information has been entered
The below feature caused the translation to be terminated
stefanh
  • Sep 14, 2017 2:24 PM UTC
I just set the Log Debug (in FME Options) and I do get some more information.
HTTPCaller(HTTPFactory): HTTP info: Unsupported proxy scheme for
What can I do to solve this?
  • Sep 14, 2017 2:33 PM UTC
My guess is an unsupported proxy schema. Unfortunately there are some ways to set up a proxy that FME doesn't support, which could lead to this error.
Can you show us (print screens) how the proxy settings are defined?
See under Internet Explorer / Internet options / Connections / LAN Settings (and possibly also under Advanced).
If you cannot access the settings (probably due to policy restrictions), you'll have to contact your IT department.
helmoet
  • Feb 22, 2018 9:50 AM UTC
Hi @david_r, @stefanh, I ran into the same trouble, and this is what helped me.
1. Might be same trouble as mentioned here
2. Some organizations handle webrequests through a proxy server. HTTP requests have to bear authentication to pass the proxyserver, only if that one succeeds, the request is forwarded to the URL requested.
3. For the request I used, there were also two kinds of authentication needed: to access the webserver I was getting data from, AND to pass the proxyserver.
- The authentication for the server is provided in the HTTPCaller
- The authentication for the proxy is provied from Tools>FME Options>Network
       * Use system proxy settings
       * Proxy server requires authentication
       * Username/Password from the organization
       * Be sure to select the correct Authentication Method
RISK: If you use this for the automated start of your workspace, then your password may expire after a password change because it is typed incorrectly three times (by FME when accessing the Proxy). However, just selecting "Use system proxy settings" might also do the trick.
