Copying values from one list to another
  • Jul 20, 2016 2:08 PM UTC
  • 125 views
darren
Hi, I have a list of dates in a list called _inputlist, I then need to run these sequentially through a loop and test each entry to see whether it is in the past, is today or in the future. This much is easy enough as I can create a custom transformer, use the DateDifferenceCalculator to calculate the number of days between the date value of the list item and the value of a TimeStamper and then test for values => 0.
The next part is the one I am having trouble with. I would like to store those dates that pass the tester into another list (called _outputlist) but I'm not sure how to assign the values to this list.
As an example, this is how I would like it to work;
_list{0} = _outputlist{0}
_list{1} = (failed tester, discard value)
_list{2} = _outputlist{1}
_list{3} = (failed tester, discard value)
_list{4} = _outputlist{2}
_list{5} = (failed tester, discard value)
I suppose I want something that will allow me to set @Value(_outputlist{@Value(_outputcounter)}) = @Value(_list{@Value(_counter)}) with _outputcounter and _counter being controlled independently.
I've tried AttributeCreator but whilst I can enter @Value(_list{@Value(_counter)}) as the Attribute Value I don't seem to be able to enter a similar expression in the New Attribute column.
I'm probably missing something simple but any assistance would be appreciated.
Many thanks
Darren
Best answer by takashi
Hi @darren, if all the failed element values are identical, a ListCopier and a ListElementFilter (FME Hub ) might be helpful. The parameters for the ListElementFilter may be:
  • Filter Type: Exact Match
  • Match Expression: <the value that indicates failed elements>
  • Negate Filtering Condition: Yes (keep only elements that don't match the value)
  • Jul 20, 2016 2:35 PM UTC
Hello Darren,
Maybe you can assign a unique id to each feature and use a ListExploder to break _list into features.
Then test for you dates and discard unwanted dates.
Finally use a ListBuilder grouping by your unique id to create _outputlist with the remaining dates.
Regards,
Larry
  • Jul 20, 2016 3:06 PM UTC
gio
Forum|alt.badge.img+15
  • Jul 20, 2016 3:47 PM UTC
explode it and create new list grouped by passed criteria and some ID as suggested.
In the new attribute column you would have to type (can't select it):
@Value(@Value(someattriubte))
in your case it would be @Value(@Value()}))
Wich then forces you to expose them. Would'nt do that unless you see no oter way.
darren
  • Jul 26, 2016 10:38 AM UTC
Many thanks for the responses, @takashi seemed to provide the simplest solution with some minor tweaks;
  • Filter Type: Numeric Range
  • Match Expression: (,@Value(_timestamp))
This filters out all list elements where the value is less than the value of _timestamp (i.e. in the past). I was initially concerned that the Numeric Range option would only provide a straight 'less than' filter but it looks like the results are coming out as 'less than or equal to', which is exactly what I was after.
