Connection Encryption
  • April 29, 2014
  • 11 views
We are trying to connect to Microsoft Azure SQL DB in cloud thru our client FME to transfer data.
Is it possible to connect SQL Azure with Encrypt connection option from client FME as available for SQL Server and shown in the attached screenshot.
 It's critical to our deliver  can someone in FME support reply ASAP ?
Thanks & Regards
Best answer by david_r
at first sight it doesn't seem like it's supported. However, I recommend you contact Safe support (https://safecommunity.force.com/knowledgeSubmitCase) directly to get the full details.
David
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
  • April 29, 2014
David
