Combine so only a single row for each discipline feature.
  • Oct 18, 2023 11:46 PM UTC
  • 5 replies
  • 82 views
jp12212
Forum|alt.badge.img+4
Hi there,
This one is fairly simple, I want to combine so the duplicate count is on a single row for each discipline feature:
should look like:
Duplicate Unique
Rail Track and Civil 40 22
I've tried aggregator and attributepivot and haven't quite got it across the line!
Cheers!
jp12212
  • Oct 18, 2023 11:49 PM UTC
***Formatting was lost, should look like:
hkingsbury
Forum|alt.badge.img+73
  • Oct 19, 2023 8:00 PM UTC
This approach can be more efficient, but for the sake of explaining i've left it a bit clearer....
  • split the data into two branches, one for unique and one for duplicate (use a tester)
  • Create a new field called unique for the unique branch and set the value as the count. Do the same for the duplicate branch
  • Using an aggregator, set group by as the discipline and make sure its set to aggregate all fields
jp12212
  • Oct 19, 2023 11:59 PM UTC
Thanks a bunch, I've just encountered this issue with the aggregator (I've isolated the issue to happen just after it runs).
I've noticed an issue with the aggregator settings: the "non-outlier" value is appearing in the outlier column. Can you help clarify this? I believed I set it up correctly, but I'm still new to aggregators.
Scaled version of workbench attached.
Aggregator_settingsinspector8.1whole
hkingsbury
  • Oct 20, 2023 1:28 AM UTC
you've got two features with values in the 'outlier' field, so its taking the value of the first feature in and using that. As I can't see what the raw data is, i'm assuming the outlier field already exist in the input data.
Probably easiest to rename the outlier branch to something different, 'outlier_agg' for example, then after the aggregator rename it back to 'outlier'
jp12212
  • Oct 24, 2023 10:42 PM UTC
thanks, this was very helpful.
