Combine a raster and list with same unique ID into a single report / PDF
  • Aug 30, 2019 5:11 PM UTC
  • 5 replies
  • 79 views
lobsterboy
I used the transformer MapnikRasterizer to create a raster for a specific data set.
I want to combine this raster with a list that has the same the same unique ID into a single document.
How can I create this list and combine it with a raster into a single document?
For example, in the photo below:
I want a list showing the records of BW #SW-0127, BW# 316002, and BW# 318003 on the first page,
with a raster of the spatial extent (created with Mapnik Rasterizer) on the second page if possible
gio
Forum|alt.badge.img+15
  • Sep 2, 2019 12:19 PM UTC
@lobsterboy
You can create pagenumbers on the records.
Aggregate and then counter.
I used "pdf_page_number_" as Count Output Attribute
Your example would get 3 pagenumbers.
Now you need to insert pagenumbers for the rasters, to make em paired.
You can do that using attributecreator with these 2 expressions.
on one set (for instance your text objects): Value(pdf_page_number_)*2+2
and the other set: @Value(pdf_page_number_)+@Value(pdf_page_number_)*1+1
("pdf_page_number_": the underscore at end is to prevent conflict with the pdf-formatter, which uses this attribute)
This gives u alternating nrs. for a set ( uniqueid).
Create multipage by setting the pdf_page_number_ as Layer Name on the pdf writer.
(if you use a pdf-formatter, as I did, take care to not use "pdf_page_number" as the formatter will overwrite it. FME should allow attributes/parameters there..but they have not, alas.)
Inserted a sample script. It puts any district on right/even page and its neighbourhoods on the left/uneven page.alternatepagenumbering.fmwt
gio
  • Sep 2, 2019 12:31 PM UTC
@lobsterboy
Here is a annotated and cleaned version of the script.
gio
  • Sep 2, 2019 2:47 PM UTC
added info:
2 page view cannot be set using fme (AFAIK).
But in acrobat pdf reader u can: view=>pageview=>display 2 pages
gio
  • Sep 4, 2019 9:45 AM UTC
@lobsterboy
You could post your workbench and sampledata if script is not clear for you. Or at least sampledata.
gio
  • Sep 4, 2019 3:43 PM UTC
@lobsterboy
Cannot donwload your workbench, get an error.
Try repost it? (firefox usualy works better then Explorer for this)
