Can I schedule to run a batch file (FME Desktop) from a SQL Server Agent job on another server?
  • Dec 11, 2017 6:29 PM UTC
  • 96 views
Best answer by fmelizard
Hi @thaonguyen, although I have not personally tried this, I would be wary of the credentials you are using to log into the database. If you are reading/writing SQL Server in your workspace, ensure that you're not using Windows Authentication when you go to try and run it with SQL Server Agent.
fmelizard
Forum|alt.badge.img+22
  • Dec 11, 2017 10:53 PM UTC
  • Dec 13, 2017 1:30 AM UTC
Thank you.
