Can Condition Statement use [a-z] to check if value has a letter in it?
  • Mar 23, 2018 2:31 PM UTC
  • 270 views
I am using a Condition Statement in the AttributeManager to check if the attribute ends with a letter. Using [a-z] does not seem to work and I am assuming it is because the test sees it as text not a Regular Expression.
Is there a way to get this to work or do I need to have a Test Clause for each letter of the alphabet?
Regards
Best answer by david_r
Try this instead:
The $-sign at the end of the regex means "end-of-line"
  • Mar 23, 2018 2:38 PM UTC
Try this instead:
Try this instead:
That sure did it, thank you kindly. Is there a way to have it not be case sensitive?
  • Mar 23, 2018 2:48 PM UTC
You can use the following expression to match both lower and upper case:
[a-zA-Z]$
[a-zA-Z]$
That is perfect, thank you so much.
Cheers
