Bulk Mapping Negative attributes to 0
  • Mar 30, 2020 1:44 PM UTC
  • 161 views
jacklonsdale
Forum|alt.badge.img+5
I have a set of 24 attributes each with a calculation which results in a numeric value. Is there a way to set a conditional statement across all of these in a similar way to how the NullAttributeMapper works?
I want to apply across all 24 attributes "If value <0, then map to 0" but i want to try and avoid 24 individual conditional statements within an AttributeManager.
Thanks,
Jack
Best answer by redgeographics
This kinda feels like cheating but...
You can use a regex in the NullAttributeMapper:
The second option, "Or If Attribute Value Is:" only seems to accept specific values so this is probably the easiest workaround.
Forum|alt.badge.img+63
jacklonsdale
  • Mar 30, 2020 2:07 PM UTC
Don't mind a cheat! Thanks, worked perfectly.
  • Mar 30, 2020 2:09 PM UTC
Hi @jacklonsdale, alternatively you can use the ExpressionEvaluator with the Overwrite Existing Attributes mode.
@CurrentAttribute() < 0 ? 0 : @CurrentAttribute()
jdh
Forum|alt.badge.img+41
  • Mar 30, 2020 2:12 PM UTC
I would use an ExpressionEvaluator after the AttributeManager in Mode Overwrite Existing Attributes with the expression
and select your 24 attributes to overwrite.
