Batch deploy for 2 inputs
  • Sep 15, 2016 8:26 AM UTC
  • 6 replies
  • 89 views
Hi ,
I have 2 input readers , a GDB an a DGN files , and 1 output DGN file , and I need to execute the process in a batch deploy , with a input directory and a output directory , but I don't know how can I do it if I have two inputs.
With one input is easy , with a path reader sending any path input to a workspaceRunner , but with two diferent inputs ?? any idea ??.
thanks for your help !!
Best answer by itay
Hi @xavigarciamar,
A second Directory and file pathnames reader connected to a second workspacerunner, is that an option?
itay
Forum|alt.badge.img+19
  • Sep 15, 2016 9:03 AM UTC
Hi @xavigarciamar,
Hi itay , thanks for your continuosly help !! I'm not sure , you believe that it will works ?? If I have for example , 3 GDB's and 3 DGN's , associated one to one , how the system will know what GDB goes with his corresponsive DGN ??? Do you think that it can works ??? I must have the same input directory for the DGN and GDB's , and it must be in a batch deploy ... thanks again !!
Thinking in your solution , I believe that it will works , but it limits the number of the inputs to the number of folders ... you another idea Itay ??? thanks !!
itay
  • Sep 15, 2016 10:00 AM UTC
Hi, It is not clear to me what you are trying to achieve, can you post your workspace or an image of it?
Hi Itay again ,
I don't attach the workspace because is a problem of directorys and inputs of the reader and with the workspace you will not see the problem , I'll try to explain you again , sorry I haven't been explained correctly.
I have a FME diagram that have two readers of input , a DGN and a GDB file. I want to create a batch deploy process able to take diferents inputs in a directory and generate with a batch process the output.
For example , I have DGN_1 and GDB_1 that must be translated in process , but I also have , DGN_2 and GDB_2 , DGN_3 and GDB_3. Any number , 1 , 2 and 3 indicates that must be processed any pair of files in diferents process. DGN_1 and GDB_1 will execute FME process and generates output_1 , and the same for 2 and 3 ...
But the 6 files must be in the same directory of input for the readers.
I have explained ¿¿¿ sorry , is difficult to explain ... thanks again !!
Finally I have created like say Itay , with different paths and workspace runner , it's limited to a number specific of inputs , but it works , thanks again !!
