Attributes in a list transposed across as new columns in excel
  • Jan 29, 2019 4:16 PM UTC
  • 14 replies
  • 249 views
bwasserstein
Participant
There's a number of other similar posts out there, but I can't seem to find a solution that works. I'm still trying to build a workflow for this on my end, but I figured I'd post here to see if anyone knows of an easy solution.
I have data in a table that looks as follows...
IDSecondary ID1ABC1231DEF3451GHJ6782DEF3452XYZ7893VWX5674ABC123
And I'd like to transpose this across a spreadsheet so that it looks as follows...
IDSecondary_ID_1
Secondary_ID_2Secondary_ID_31ABC123
DEF345
GHJ678
2DEF345
XYZ789
3VWX567
4ABC123
The problem I'm hitting a wall with is that there may be any number of Secondary_IDs for a given ID...potentially a couple hundred for a single ID. So, I'm looking to have a tabular data set in the end that may have a couple hundred columns, with a single row for each ID.
Is this possible? I'm trying to wrap my head around using list attributes, but am struggling to find a solution to output each attribute value in a list as it's own column. I only need one list attribute for the Secondary_ID values as far as I'm aware.
I'll keep playing around and I'll post any solutions that I find.
Thanks for your time.
FYI...I'm running FME 2015.0 (20150114 - Build 15245 -WIN32) via ArcGIS data interoperability extension.
Forum|alt.badge.img+54
  • Jan 29, 2019 4:46 PM UTC
It's possible but not particularly straightforward in current versions of FME. Not sure whether the same sort of workflow would work in 2015
bruceharold
Forum|alt.badge.img+20
  • Jan 29, 2019 4:50 PM UTC
Ragged edge tables are seldom fun to work with, can you refactor the problem to (say) output a worksheet per ID value and keep Secondary ID in one column?
bwasserstein
Participant
  • Participant
  • Jan 29, 2019 5:06 PM UTC
Potentially, but I may have to change things further down the line & we already have a script set up to work with such a ragged edge table. Perhaps we need to make some changes in that regards though.
Now I know I could do that with a ListBuilder/ListConcatenator, and it seems it'd be wise for me to use a ListElementCounter to get an idea of how many columns I would need.
Anyhow, I've built a very non-elegant solution. I'm just building a list and setting up an AttributeCreator to output a new attribute for each list element number.
e.g., AttributeName = Secondary_ID_1, Value = @Value(_list{0}.Secondary_ID)
AttributeName = Secondary_ID_2, Value = @Value(_list{1}.Secondary_ID)
AttributeName = Secondary_ID_3, Value = @Value(_list{2}.Secondary_ID)
...and so on until I've created enough new attributes to hold the max count from the ListElementCounter.
Perhaps a more elegant solution will come to mind & if so I'll post here.
Thanks all for the quick feedback.
  • Jan 29, 2019 5:16 PM UTC
This is how I would do it in 2018
and the python to avoid having to manually expose attributes
import fme
import fmeobjects
def create_schema(feature):
    attrlist = feature.getAttribute('_list{}.Sec_ID_Name')
    feature.setAttribute('attribute{'+str(0)+'}.name',"ID")
    feature.setAttribute('attribute{'+str(0)+'}.fme_data_type','fme_char(20)')
    for i, val in enumerate(attrlist):
        feature.setAttribute('attribute{'+str(i+1)+'}.name',val)
        feature.setAttribute('attribute{'+str(i+1)+'}.fme_data_type','fme_char(20)')
bwasserstein
Participant
  • Participant
  • Jan 29, 2019 5:21 PM UTC
import fme
import fmeobjects
Thanks a boat load egomm. I should be able to set up that same workflow in 2015.
Do you mind sharing the Python code in your PythonCaller? I will admit... my python skills are lacking.
Thanks again.
gio
Forum|alt.badge.img+15
  • Jan 29, 2019 5:24 PM UTC
@bwasserstein
Listbuilder on ID, explode. Increase value of elemtn index by 1.
Concatenate this with Secondary_ID_.
Create attribute @Value(_result) = @Value(Secondary ID)
Expose Secondary_ID_1 to Secondary_ID_n (create list in excel by increment and import in exposer)....
aaah..can't import in fme_2015. Well hope you don't have hundreds of ID nrs then. (upgrade FME?)
aggregator on ID, drop attributes, use attriubtus to concatenate on Secondary_ID_1 to Secondary_ID_n with no separator.
Now you're done
gio
  • Jan 29, 2019 5:37 PM UTC
@bwasserstein
Now you're done
here is result
  • Jan 29, 2019 11:58 PM UTC
If you populate Secondary IDs grouping by primary ID into a list, you can just rename each element to a desired name with the AttributeRenamer.
gio
  • Jan 30, 2019 10:26 AM UTC
@takashi
Of course that's possible.
Just not very attractive because then you can't import a attribute names . Unless you create a mapping first and import that, which kind of defeats the purpose as it is clearly less efficient.
I simply create a mapping for this type of enumerated attribute name in say excell, making it very as large as anticipated need.
When not enumerated I just copy the list from the feature information window and parse it using like notepad++.
You could replace the exposer with python attributecreation ass the data is enumerated.
I guess doing that would increase the dataset by 2.
This will go on till safe figure out how to blindly expose everything hidden.
  • Jan 30, 2019 10:36 AM UTC
@takashi
If you are writing it out dynamically to excel, there's no need to expose the attributes in the workspace
gio
  • Jan 30, 2019 11:43 AM UTC
@egomm
So I can dynamically write dynamically created attributes?
How would the schema be created?
Always keen to learn some new technique, I am.
  • Jan 30, 2019 11:46 AM UTC
@egomm
pivot_example.fmwt An example @gio
gio
  • Jan 30, 2019 12:04 PM UTC
@egomm
To get to the attributes I would have to read the file again and still not know what the attributes are, unless I sacrifice dynamism.
Exposure of enumerated attribute names makes it possible to access them in the workbench. (I simply create a long import list)
Not required for the solution of this topic I admit.
But for this topic probably adequate.
bwasserstein
Participant
  • Participant
  • Jan 30, 2019 3:26 PM UTC
Thanks Takashi. This is yet another solution! I currently have an AttributeCreator built into a similar workflow rather than an AttributeRenamer.
I'm still probably going to take a crack at setting up egomm's workflow if I have time. I'll be pushing a number of disparate datasets with identical schema thru this workflow, and I never know how many Secondary_ID values there may be for a given ID... I suspect up to a few hundred for some of these datasets. I can set up the AttributeRenamer/Creator to accommodate this, but egomm's workflow is definitely more elegant.
Thanks all for your help. It's much appreciated.
