attributes from autocad block
Hello!
How I can to take this attributes from autocad block?
I need it for converting to postgis database.
I don't see these attributes in FME inspector
pratap
Forum|alt.badge.img+11
  • May 15, 2015
It will be in format attributes which needs to be enabled in the reader. For block name, you have to enable the format attribute named "autocad_block_name".
I don't understand the other attributes as they are not in english...
Pratap
  • May 15, 2015
Many thanks for the response,
 1) When I use "autocad_block_name" in format attribute I sometimes get the system name of the block:
2) about other attributes:
  I understood that these attributes from object data, but I don't know how I can get it.
  • May 18, 2015
I already use "autocad map 3d Object Data" reader, but I can't find these attributes
pratap
  • May 18, 2015
Is it possible to provide a sample file?
Pratap
  • May 18, 2015
pratap
  • May 18, 2015
Thank you for sample. I'm able to view the attributes with value "111" shown in below screenshot...
As shown in the above screenshot, Do you want to see the attributes of "view" or "class"?
Pratap
  • May 18, 2015
yes, I want to see "view" and "class"
pratap
  • May 22, 2015
These seems to be object classes but not object data.
  • May 22, 2015
Thank you, Pratap. Can I get object classes with FME?
pratap
  • May 22, 2015
I'm as well new to this object classes as I have never seen before. I will let you now if came to know regarding this...
