Attribute pivoter not working anymore while upgrade to arcgis 1.8 was done.
After a upgrade to 1.8. arcgis FME data interoperability model does not work anymore.
Type of an error i am getting :
Python Exception <TypeError>: '<' not supported between instances of 'str' and 'float'
Traceback (most recent call last):
File "__init__.py", line 163, in close
File "__init__.py", line 261, in generate
File "__init__.py", line 298, in summaryData
File "__init__.py", line 417, in summarize
TypeError: '<' not supported between instances of 'str' and 'float'
AttributePivoter_2 (PythonFactory): PythonFactory failed to close properly
AttributePivoter_2 (PythonFactory): A fatal error has occurred. Check the logfile above for details
Forum|alt.badge.img+39
  • May 4, 2021
There's a known issue with the AttributePivoter and newer python versions, see the last response from @hollyatsafe (Safer)​ safe here
https://community.safe.com/s/question/0D54Q000080hgfmSAA/statisticscalculator-error-with-python-36
  • May 4, 2021
Thanks a lot!
i have foud a workaround that works for me.
  • June 21, 2021
miharobar wrote:
Thanks a lot!
Hi @miharobar​,
Great to hear that you found a workaround. I have the same error with the AttributePivoter. Could you share your workaround? Perhaps it also helps me with my problem.
