Attribute Name User Parameter issue FME Desktop 2019.1
  • Jul 24, 2019 11:55 AM UTC
  • 6 replies
  • 142 views
Hi all,
I have an issue in new FME. I'm trying to set up User Published Parameter that will give user list of attributes available in workbench. But after choosing a Type: Attribute Name it doesn't see any attributes available. As my input I use shp files.
Is it a bug or I didn't do it properly?
Regards
Best answer by stalknecht
This is by design. Parameters are initialized before running the workspace.
stalknecht
Forum|alt.badge.img+22
  • Jul 24, 2019 1:15 PM UTC
  • Jul 24, 2019 1:17 PM UTC
It's not entirly clear to me, but are you perhaps trying to set the attribute name from within the custom transformer? If so, that is not possible, you can only set the attribute name from the custom transformer instance.
Not possible, I'm inside the custom transformer:
OK, here I'm modifying the settings of the custom transformer instance:
  • Jul 24, 2019 1:50 PM UTC
Thank you for answer. But is there any way to make it possible to define attribute name at the beginning of the process? Column name is not constant so I would like user to insert that name.
  • Jul 24, 2019 1:53 PM UTC
Yes, I created it via Navigator. Because I want to use this in several transformers as Group By choice. Also it need to be chosen by user during running translation.
You could consider using a regular text field for the attribute name.
  • Jul 24, 2019 2:12 PM UTC
OK, inserting User Parameter as text in single apostrophes worked!
