aggregate values in key-value pairs and write matrix
  • May 22, 2018 7:41 PM UTC
  • 5 replies
  • 97 views
vki
Forum|alt.badge.img+8
This is my initial data:
Name,Value
sza034,ber_afu
sza033,ber_awn
sza034,ber_afl
sza033,ber_afu
sza034,ber_afu
sza032,ber_awn
sza034,ber_afl
sza033,ber_fff
sza033,ber_bgt
sza033,ber_afu
sza033,ber_jij
The result has to be a matrix, with a row for each unique name and a column for each unique value.
the fields in the matrix have to be filled with "yes" or "no":
Name,gschber_afl,gschber_afu,gschber_awn,gschber_fff,gschber_bgt,gschber_jij
sza034,yes,yes,no,no,no,no
sza033,no,yes,yes,yes,yes,yes
sza032,no,no,yes,no,no,no
By using the Aggregator, AttributeSplitter, ListDuplicateRemover and ListSorter, I managed to get for each name a list with its unique values. But how can I write this matrix now?
Thanks in advance.
Vera
  • May 22, 2018 9:58 PM UTC
Hi @vki, this workflow might help you.
jdh
Forum|alt.badge.img+41
  • May 22, 2018 10:50 PM UTC
If your potential values are static (don't change) then use takashi's workflow. If they are dynamic, or there are too many to manually expose, here's an alternative.
keyvalueyesno.fmwt
vki
  • May 23, 2018 1:57 PM UTC
Thanks for your answers. takashi's one was perfect for me.
vki
  • Jan 29, 2021 9:21 AM UTC
keyvalueyesno.fmwt
@jdh​
I have to come back to this post, for now I need a solution for dynamic values...
Unfortunately, I can't download keyvalueyesno.fmwt anymore.
Could you explain me, how you managed to create a dynamic matrix?
Thanks, Vera
jdh
  • Jan 29, 2021 2:54 PM UTC
@jdh​
Thanks, Vera
It turns out I still had the workspace. The MergedSchemaSetter has since been replaced with the SchemaSetter on the hub.
