Add list attributes which are the sum of all values before; 1 2 3 --> 1 3 6
  • Apr 14, 2016 1:33 PM UTC
  • 101 views
Example:
I've got a list: "_list" with as attributes _list{}.ratio.
  • _list{0}.ratio = 0.10
  • _list{1}.ratio = 0.25
  • _list{2}.ratio = 0.30
And I want to add a list attribute: _list{}.ratiosum with as result:
  • _list{0}.ratiosum = 0.10
  • _list{1}.ratiosum = 0.35
  • _list{1}.ratiosum = 0.65
In Python I would do it like this:
sumlist = []
s = 0
for i in range(len(ratio)):
s = s + ratio[i]
sumlist.append(s)
But how is the relation between the python and the list in FME? This doesn't work:
def processFeature(feature):
    s = 0
    for i in range(len(feature.getAttribute{'_list{}'));
        s = s + ratio[i]
        feature.setAttribute('_list{%d}.ratiosum' % i, s)
This gives an syntax error; it is not possible to get the length of the list with the len() function?
Best answer by takashi
Hi @erikjh, "feature.getAttribute('_list{}.ratio')" returns a list containing the elements as string values. For example:
    sum = 0.0
    ratios = feature.getAttribute('_list{}.ratio')
    for i in range(len(ratios)):
        sum += float(ratios[i])
        feature.setAttribute('_list{%d}.ratiosum' % i, sum)
or
    sum = 0.0
    for i, r in enumerate(feature.getAttribute('_list{}.ratio')):
        sum += float(r)
and so on.
  • Apr 14, 2016 3:11 PM UTC
    sum = 0.0
or
    sum = 0.0
        sum += float(r)
and so on.
Hi @erikjh
you can also try a no-Python option:
  • ListExploder to explode the list into individual features;
  • StatisticsCalculator > Cumulative to get ratiosum values;
  • Aggregator to combine multiple features back into a single feature with a list attribute.
Lena
  • Apr 15, 2016 10:37 AM UTC
Thank you very much! This will help me a lot.
