195 character limit for FME_SERVER_REQUEST_URI in FME Server?
  • Apr 20, 2018 3:53 AM UTC
  • 114 views
andybates
Hi guys,
can someone please confirm if there is a character limit to the FME_SERVER_REQUEST_URI in FME Server 2017.1? It seems to be 195 characters.
For example, I have a schedule that is calling a workspace :
https://myservername.com/fmejobsubmitter/a_long_repository_name/and_a_really_long_workspace_name.fmw
If that string is over 195 characters then the scheduler reports that the workspace cannot be found. It works fine if I reduce the length of the repository name or the workspace filename.
Cheers
Batesy
Best answer by redgeographics
Are you running on Windows? There seems to be a max file path length there of 259 characters which may come in to play here (it's not the same number as you're reporting but it's close enough to warrant suspicion)
Another thing, if you have lots of parameters with long values, might be the 2048 character limit on url's, as described here.
Forum|alt.badge.img+63
andybates
  • Apr 23, 2018 1:04 AM UTC
Hi @redgeographics, thanks for the reply.
Yep, I'm pretty sure you are correct and it's the 259 character limit in Windows! I realised this morning that when the workspace is uploaded into FME Server it creates another sub-folder with the same name as the workspace within the "repositories" folder so you end up with :
C:\\ProgramData\\Safe Software\\FME Server\\repositories\\repository_name\\subfolder_workspace_name\\workspace_name.fmw
I guess in the future I should keep my repository / workspace names nice and short and used the description field to provide the context instead...
Thanks for the help,
Batesy
