Unable to log in to Web User portal
As the subject line states… This is a fresh installation of FME Server v 2019.1.2 Build 19630.
I enter U: Admin P: Admin and it takes me right back to the login interface.
The installation docs online state the following:
Confirm that FME Server is available:
Log in to the Web User Interface with the username and password you entered during installation.
There was no prompt to enter a user name and password during installation.
FME Server is installed on a Virtual Machine - Windows 2016 Server
Any help would be great
fgiron
Forum|alt.badge.img+20
  • October 3, 2019
Are you trying Admin/Admin or admin/admin? It should be the latter.
erik_jan
Forum|alt.badge.img+18
  • October 3, 2019
The FME Server 2019 are case sensitive.
Have you tried admin/admin as those are the default settings?
  • October 4, 2019
The browser was the issue - IE 11.
I switched to Chrome and was able to log in.
Hi @wahahn,
When you opened FME Server's Login page through IE had the page also failed to load correctly, that is, missing text and login button not fully visible? If so I believe IE Security settings are at play, by adding your machines IP address to IE trusted sites you should be able to use IE browser to access FME Server.
Ref: https://knowledge.safe.com/questions/48691/why-does-my-fme-server-web-interface-not-show-a-lo.html
